Distributor testing
- OldRedFord
Distributor testing
Can you test a used distributor to see if it works? I have a points one for a 429/460 and want to run it until I can afford to get a complete duraspark setup.
Tim
1972 F350 flatbed drw c6/390
1967 F600 project truck
Re: Distributor testing
i guess you could hook it up and then spin the drive gear.
- Dragon
Why would you need to, put the points and condenser rotor and cap on and go. THe chances for your use of the dizzy causing any problem is rare. The mechanical section even wore out will still work unless it is rusted up.
Old Fords Rule
Was a Ford Service Tech
98 Volvo S70 2.4T Auto
My Gallery
Spark test
My Gallery
Spark test
make sure you are holding on to it real tight when you hook up power to the points and spin it (ha ha).
If the shaft bushings aren't worn and the cam opens the points It should work.
