I have a 1970 f-100 6cyl motor is a 85 ford
I had her running then went to start it turned over then just stoped. Now won’t turn over and the light won’t turn on
The batter is new and good.can anyone help me out ??
Starting problems.
Re: Starting problems.
This is gonna sound dumb but reclean the battery posts and terminals with a little 200 grit sandpaper - I changed the battery in mine and 2 days later it wouldn't do anything until I did that.....easy place to start......
1997 Honda CBR 900RR
- Jacksdad
I second that. Check your battery terminals and grounds.
I wish it was that but it is not I did that and still nothing.
- bluef250
I suggest that you pull the battery and have it load tested.
Thanks all the grounds as stated were not too good
