Gauges Needed TX Inspection
lone_ranger
Post by lone_ranger »
This is my first post here, so here it goes...
I'm restoring a 1970 f100. One of my many plans with this truck is to get it registered so I can drive it legally. The truck currently has no dash.
I was wondering if anyone knows which gauges I need to have in working order in order to pass a TX inspection so I can register the truck. I'm assuming I need a speedometer, and fuel gauge, but I'm not sure how many more I may need.
I am planning on ordering after market gauges for this and will certainly add more gauges later, but I just want to get this truck street legal so I can drive it to a shop for specific work.
Mancar1
Re: Gauges Needed TX Inspection
Post by Mancar1 »
You may want to just call the inspection station and ask what need to b on the truck and in working order.
In addition to what u r thinking, I would think a temp, oil, and amp.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
1972hiboy
Post by 1972hiboy »
Rich
Dont eat yellow snow.....
tac
Post by tac »
This is it :yt: All you need on the dash board is the high beam indicator. They don't care if you know how fast your going, but you better know if you have your high beams on :lol:
lone_ranger
Thanks for the guidance. I contacted an inspection station. I need a speedometer, odometer, turn signal indicators, high beam indicators, and parking brake indicator. It's wiring time...
mrollings53
Post by mrollings53 »
I'm fairly certain these trucks didn't come with a parking brake indicator.
Mancar1
Post by Mancar1 »
Maybe they r speaking of the brake proportional light/indicator
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
tac
Post by tac »
Get a second opinion. I had one refuse to inspect my truck because it didn't have the exhaust exiting from under the bed, showed him in the manual the exemption for original equipment and he still wouldn't do it. Went to another and no problem. Hope he doesn't get any 30's 40's cars without turn signals and only one brake light.
motzingg
Post by motzingg »
They do have a high beam light! It is very dim and red right behind the speedo. I spent 3 hours getting it working last time i had my truck inspected and the inspector didn't even check.
I've heard both things about the speedometer, that list doesn't say anything about it. I've never brought in a car that didn't have one, but it looks like they can't flag you for that.
"I need a speedometer, odometer, turn signal indicators, high beam indicators, and parking brake indicator"
i think that is B.S. and i'd call around for another inspection station. they don't say anything on the website about all that except the high beam indicator. which is dumb, but... whatever.
parking brake indicator?!? if they ask you that just say "when you see that pedal looking thing near the ground, it is an indication to the operator that the parking brake is engaged"
if they flag you for things that aren't on the list, call TXDOT and report them for fraud.
