So after a couple of times of the truck continuing to run for a couple seconds after I turned the key off, now it continues to run until i kill it by dropping the clutch. The radio also stays on, so I'm assuming there's a bad connection in the run position inside the ignition. Just looking to see if anyone had any other thoughts before I ordered a new one.
Thanks
Think i need a new ignition
Re: Think i need a new ignition
That's what I'd do. Cheap and easy swap. Be gentle removing the plug. They tend to get brittle with heat and age.
- Randle
The timing, or the carburetor not closing all the way can cause it to diesel when you shut it off.
That's what I thought at first when it only ran for a few seconds. But now it will run until I kill it and with the radio staying on desieling doesn't seem likely. Thanks for your help, guess I'll order an ignition.
I had same issue . But I could unplug switch and still stay running !!!!! I found if I bumped starter then turned key off truck would die ... Replaced starter relay so far it appears to fix the issue .
- Craigerf100
Ignition switch.
I had the same problem on a fairlane and ignition switches at time were not available. So i spliced in a generic horn button between the hot 'starter' wire off the switch. And turned it into a push start
With the key in Of course.
Problem solved.
Problem solved.
1968 F-100 Short Bed
1967 Fairlane 500 Convertable
1967 Fairlane GT/A 289ci SOLD
My Build:
My Build:
- Craigerf100
If they're cheap buy a new one.
My Build:
My Build:
