Hard starting/drags when hot
Ford110
Post by Ford110 »
I have a 67 f100 4wd with a 390 and no headers. With new battery, turns over/starts fine when cold. When hot, turns over slow/drags but starts right up as soon as one cylinder fires. Starter gone? Timing?
charlie bumpside
Re: Hard starting/drags when hot
Post by charlie bumpside »
sounds like your starter may be dragging when its hot
1971 f100 ranger xlt 1972 sport custom 2003 f250 super duty
ok68crewcab
Post by ok68crewcab »
I am thinking bad starter as well
2 Blessed 2 Be Stressed
cep62
Post by cep62 »
Make sure your timing isn't too far advanced .
and get "BIG" battery cables (00 ga)
If it still turns slow then look at the starter.
Don't overlook the cable from the solenoid to the starter
and the ground wire to the block and solenoid / rad support.
Ford110
Post by Ford110 »
Thanks
