Blower motor resistor
rdaniel911
Post by rdaniel911 »
Is there anyone out there that knows of a source to buy a blower motor resistor for a 68 bump, when I pulled the heater casing apart to refinish it, mine crumbled. Can't find it at the local parts house anymore.
Robert & Linda
2011 F-150 Supercab
2017 Ford Edge
1969 Mustang Fastback
1968 F-100
http://s297.photobucket.com/albums/mm21 ... 8%20f-100/
Mach428
Re: Blower motor resistor
Post by Mach428 »
Try NPD
max03
Post by max03 »
When you find a source, please post! I'm in need of one aswell I do suspect.
72 lwb sport custom, 300/3spd
pdb,ps, ac 3.70:1
68-swb 300/3spd sold
69-lwb 390/c6 sold
69-swb 240/c4 sold
72-swb ranger xlt 360/c6 sold
72-swb sport custom 302/3spdsold
rdaniel911
So far its not good, no one I have talked to has one, nor do they know of a source for any.
Robert & Linda
2011 F-150 Supercab
2017 Ford Edge
1968 F-100
68RGR
Post by 68RGR »
Check out the photos at these links. The first is for 1970s trucks and the second is 1980s:
http://macsautoparts.com/heater-blower- ... HL1104164/
http://www.carpartswholesale.com/v5/det ... U439.html/
If the photos look close, you might try one of them. But, they ain't cheap!
If you still have the remains of the old resistor, does it have two coils?
And, if the coil(s) are still intact, can you accurately measure the resistance of each one?
I ask because, depending on the current draw, you might be able to replace them with standard electronic parts. Power resistors are available in rather large wattages.
For instance, if the value was one ohm and the current was 5 amps, the resistor would dissipate 25 watts. Of course, you'd want to use a larger wattage like, say, at least 50 watts. One good thing is (I think) the resistor(s) sit in the air flow which would help to dissipate the heat. Well, until the heater got good and warm. Then, that could be a negative factor!
Looking at the coils in the photos, it appears that one end of each is connected to a common terminal while the other ends are connected to separate terminals. This arrangement could allow for 3 or even 4 fans speeds - No resistance would be HIGH and, by using each resistor separately and in parallel, three additional speeds could be realized depending on the switch. I haven't looked at the resistor in my truck so I am not sure how it is configured. Does it resemble either of the photos?
Bill
68 F100 Ranger
73 F100 Ranger XLT
rdaniel911
neither look like it, the coil arraingment on the 68 is inline, not side by side, my coils are fine, but from looking at whats available, I may attempt to build a backing to go back on it so I can just use the remains.
Robert & Linda
2011 F-150 Supercab
2017 Ford Edge
1968 F-100
