Ford size .180" bullet connectors
- toddspeed
Anyone know where to get the Ford standard bullet connectors? Autozone doesn't have them. I did a search and found an archive thread from 2005 asking the same question and apparently they are .180" size, but no source was listed.
I need to plug into some of the factory wiring and would rather not hack the harness apart.
Thanks!
Thanks!
Todd in Atlanta
1970 F100 Ranger born the same month/year as me - 360 C6 2WD, P/S, LWB
You! Yes You! Please put your location in your profile - it helps us help you when it comes to parts, pricing, and advice.
Re: Ford size .180" bullet connectors
I found some at a NAPA store, I think they were marked as .176.
- bluef250
I have look high and low on the net and could not find any. I decided to salvage as many connectors when at pick-n-pulls and used them. Soldering the wires then using shrink wrap would give a clean (OEM) look. I don't care for crimped connectors.
- toddspeed
testing 123
Todd in Atlanta
- toddspeed
I keep getting "connection was reset" errors with Firefox - can't post?!
Todd in Atlanta
- toddspeed
argh!
Todd in Atlanta
- toddspeed
Went to NAPA and found them, thanks! I had to go through their connector catalog (so much for "NAPA know how") and find them myself. They had them hiding on a shelf in the back corner.
NAPA p/n 724104
They fit decent...I oblonged the bullet just a bit with pliers to make it snug. They are indeed .176" vs. the Ford .180".
They are around 20 cents each.
NAPA p/n 724104
Todd in Atlanta
Thanks for the info. Btw, I've given up on Firefox for the forums. I only get consistent posting with Chrome.
- bluef250
I am collecting fittings from pick and pulls for use. I will solder them and use heat shrink tubing to sealing them. The connections will look OEM and fit much better.
I gave up on MS and I'm using Firefox. No problems on home computer. At work I use MS Explorer and do not have problems!
- Art
I always saved harnesses and connectors from trucks I parted out. If previous owner(s) hacked up the harness bad, I use it for parts. The factory connectors fit best, but I have seen some crimp-on jobs whose bullet fits pretty good.
I am against only crimping connectors, as corrosion becomes an issue here in the midwest. I solder and shrink wrap almost all connections I make. If soldering is not possible, then I grease them up to keep water out! I also grease the electrical connectors as I have seen corrosion cause problems there as well - battery posts, bullet connectors, light bulb sockets, headlight terminals, all of them get a little bit of protection. Also helps them come apart easier if necessary later on.
Just had to reinstall Google Chrome myself to be able to post again... Whats up with that???
Like vintage drag racing? http://www.meltdowndrags.com
Found some 0.180 bullet terminals here:
http://www.wiringproducts.com/contents/ ... ctors.html
Not exactly cheap but supposed to be the right size. Both male and female in 14 to 22 gauge. And with integral heat shrink in 14 to 16 gauge. Depending on quantity and gender, $0.18 to $0.40 each for the "normal" ones and $0.77 to $1.50 EACH for the ones with heat shrink.
Apparently, all online orders are shipped for $6.50.
Found similar connectors at what seems to be a better price here:
http://proweldperformanceparts.com/Term ... ctors.html
Looks like the prices include shipping. But, don't count on that until someone actually places an order.
Are these what you were looking for?
Bill
68 F100 Ranger
73 F100 Ranger XLT
68 F100 Ranger
73 F100 Ranger XLT
