new Turn signal switch
67 ford f100s rule
Post by 67 ford f100s rule »
I put a brand spanking new turn signal switch in my 70 LWB. I matched up the new wires with the old wires on the connector at the end of the wiring. But my turn signals dont work. Anyone have this problem before?
Jeff Penland
70 Ford F100 LWB "Nadine" 302/3 speed with overdrive
If you have to ask you wouldn't understand
"I shall hold the line of right as well as that of glory." English translation of the British Penland coat of arms.
Re: new Turn signal switch
what was wrong before yo ureplaced the switch. the power to the turn signal switch is wire 810 in the diagrams. http://www.fordification.com/tech/wirin ... master.jpg
that wire goes through the brake light switch and gets its power from the hazard flasher can which gets is power from the fuse box.
67 ford f100s rule
I went ahead and replaced the turn signal switch when I rebuilt the column. The old switchs canceler arms had broken off so I figured I might as well replace the switch while I am in the column. The turn signals were working fine before I replaced the switch.
Jeff Penland
91Bear
Post by 91Bear »
I hear you. I did the same thing and now they come on but don't flash.
ezernut9mm
Post by ezernut9mm »
take the wheel off and push down on the ts arms and see what happens. have someone look at the lights when you do this. most aftermarket tss are junk and don't make the proper connections. i went through this on a 66 f100.
ezernut9mm wrote:take the wheel off and push down on the ts arms and see what happens. have someone look at the lights when you do this. most aftermarket tss are junk and don't make the proper connections. i went through this on a 66 f100.
that very well could be the problem.
68FORDJBM
Post by 68FORDJBM »
I doubt you have the same problem as I had but for what its worth I just spent almost 2 years trying to get my turn signals to work and it turned our being a short in my fuse box.
67 ford f100s rule
I tried what ezernut said and notyhing changed. But my dad noticed that there was a clicking noise under the hood . We traced it to what I assume is a voltage regulator next to the solenoid. It was clicking Is it possible its gone bad and that is my issue?
Jeff Penland
ezernut9mm
i can't answer that from experience, but did you try hitting it with something? lol. that's what i usually do.
67 ford f100s rule
I found I had two wires reversed. So now my left signals work but my rights do not.
Jeff Penland
NC70Bump
Post by NC70Bump »
Replaced my switch a few weeks ago and had the same problem your having. Ended up being a short in the fuse box. Removed lower right fuse and sanded down the connections, replaced with new fuse and everything works now. Worth a shot :wink:
68FORDJBM
Post by 68FORDJBM »
67 ford f100s rule wrote:I tried what ezernut said and notyhing changed. But my dad noticed that there was a clicking noise under the hood . We traced it to what I assume is a voltage regulator next to the solenoid. It was clicking Is it possible its gone bad and that is my issue?
I just found out from Fordman that the regulator next to the solenoid is the horn relay. Mine did the same thing and eventually began to be the source of my battery going dead. My horns are missing so I unplugged the solenoid and solved the problem (for the battery draw)
Thunderfoot
Post by Thunderfoot »
Check out this as some of the new switches had different colors + some of the info here might help http://www.fordification.com/forum/view ... 49&t=49462
67 ford f100s rule
I have it figured out. I have to replace a fuse now but it is figured out. Thanks everyone for all their help!
Jeff Penland
stephen44
Post by stephen44 »
:D - so are you going to spill the beans - or should we guess ? :lol:
thanks
Stephen
