What does this part do? I know it goes in the drivers door frame by the dome light activator but I can't figure out what it's supposed to do. It's got sealed up wires in the back and I only pulled it from a junkyard truck to fill up the hole in my own door. Just curious.....
What is this?
What is this?
- BobbyFord
Re: What is this?
Ambient sensor for TRS system.
Re: What is this?
I can usually figure these things out but I'm afraid I'm really lost. What is a TRS system? And what does an ambient sensor sense?
Re: What is this?
TRS Transmission Regulated Spark control device. emissions stuff.
Re: What is this?
Wow. I never woulda thought that'd be something that'd be on a truck around this era. Especially mounted on an inside door frame like that. Thanks BF and FM.....
Re: What is this?
Read the following in the Factory Literature Library:
Re: What is this?
Wow! That's great. Thank you!!
- CommrclDiver
Re: What is this?
So is it safe to say that if its not working or hooked up, the entire system can be removed from the vehicle with out problems?
Work Hard, Dive Safe!
1971 Ford F-100 2WD LWB 302 w/C-4 Daily Driver
1971 Ford F-100 2WD LWB 302 EFI Project Truck
