multimeter how-to
BigRedTruck
multimeter how-to
Post by BigRedTruck »
so I got a multimeter for christmas. I have no experience in anything electrical besides fuses,bulbs and the fact that black electrical tape can be used to fix shorts....so I got my engine steam cleaned and on the way home it started acting up and died. It happened in a very similar way to the way it failed then the coil went out. It wasn't all at once, it was a slow progressive failure. I am wondering how to check my current coil. The multimeter I have is one of those standard craftsman models. I don't know if that helps but....
thanks
PS: it did start up again and got home.
69 F-100 2wd 360 cid C6
Catapultam habeo. Nisi pecuniam omnem mihi dabis, ad caput tuum saxum immane mittam.
I have a catapult. Give me all the money, or I will fling an enormous rock at your head
granitestate68
re: multimeter how-to
Post by granitestate68 »
Hi,
Sounds like something got wet when it was steam cleaned. Points, wires, coil how's your dizzy cap? I'd check that stuff first. Sorry, can't help you with what the exact readings should be. Good luck.
Lee
http://www.fordification.com/galleries/ ... p?pos=-550
1996 F250 Slightly lifted 7.3L Diesel
1961 Falcon Ranchero 144 Inline 6
spray some wd 40 into the cap and restart the engine. Water Displacement formual 40
ladz
Post by ladz »
That will start a fire wd 40 is flammable ! Spark in the distributer.
FORDification
Site & Forum Admin
Site & Forum Admin
Post by FORDification »
:lol: No, it won't start a fire. Spraying WD-40 into a wet distributor cap is a very common thing to do, and is the quickest way of isolating the moisture and allowing you to restart.
ladz
Post by ladz »
It does say flammable on the label ! :hmm:
it is flamable your right about that just put a lighter in front of it and spray it. i think its the propellent that flamable though. fordman like to play with fire. tim allen grunt grunt
Galaxie64
Post by Galaxie64 »
Yep it is the gas that is flamable, just like pretty much every other aerosol. OFF is always fun to use as a torch
'68 F150 2wd
'72 F250 2wd Camper Special (400/C6/4bbl)
'64 Galaxie 500 (3524bbl/57K miles)
'92 Grand Marquis (mostly stock 4.6L)
'97 F150 (heavily modded 5.4L)
'48 F1 (Flat 6)
'51 F3 (Flat V8 )
'56 F350 (engineless)
** Chuck Norris has counted to infinity -- twice. **
do you do lots of mosqito killing with it.
binder56jd
Post by binder56jd »
it's great for wet dizzies- wouldn't recommend using it on your shotgun seems they will explode-jd
now serving #235
westernkansas
Post by westernkansas »
back on topic how would one test a coil to see if it is good or bad?
Thunderfoot
Post by Thunderfoot »
westernkansas wrote:back on topic how would one test a coil to see if it is good or bad?
Couple of good links with info on checking the coil with an Ohm meter. Problem is finding the exact specs for your coil, you may have to compare it with another good one that is the same...
http://autorepair.about.com/od/troubles ... st-ohm.htm
http://wiki.answers.com/Q/How_do_you_te ... ition_coil
:fr:
