1968 F100 2wd style side short bed.
- Craigerf100
Re: 1968 F100 2wd style side short bed.
Hey what do u all recommend for cooling fan switches?
Here's what I've found so far
http://m.autozone.com/autozone-mobile/e ... ber=733653
And
http://pages.ebay.com/motors/link/?nav= ... 29&alt=web
Any advice Would be great.
And
1968 F-100 Short Bed
1967 Fairlane 500 Convertable
1967 Fairlane GT/A 289ci SOLD
My Build: http://www.fordification.com/forum/view ... &sk=t&sd=a
- chad67
I know alot of people have had luck with the Scotchbrite type pads that go on a drill for cleaning machined surfaces. A completely clean surface is essential.Craigerf100 wrote:Ok so, took a scraper to the heads and the block. and most of what looked like scoring on the head came off; must of been mainly carbon build up. The blocks 'looks' fine. But time will tell I've only begun cleaning the surfaces. Wish me luck.
1967 F100 SWB
1991 Thunderbird 5.0 with fully ported gt40 heads, cobra intake (also ported) and a trickflow stage 2 cam, manual steering, and custom 3" exhaust
- BobbyFord
The best thing I've ever used for cleaning engine gasket surfaces are the 3M Roloc bristle discs. Different color discs have different "abrasiveness". I prefer the green ones.
- Craigerf100
Thanks guys.
I could u use your 2 cents on elec. Cooling fan switches.
well, as far as fan switches go I bought the painless one out of the Jegs catalogue, it consists of a sending unit thermal switch, a relay and the wiring. I use it in conjunction with a mark viii fan and they offer two temp settings. I have not had the need to install a manual override switch in the dash, it comes on like clockwork at 185 degrees. I'm happy with it .
Painless # 764-30115
- Craigerf100
Thx blue for the info.
So auto zone recommended head bolts gs33316 I found $10 cheaper a side on ebay. I would like your guys opinions. Any one use these before?
http://pages.ebay.com/motors/link/?nav= ... 88&alt=web
- Heirloom
Victors are OEM quality
~Heirloom
'68 F250 360, 4 spd Project Thread!
Plans are for a stout 400, C6, 3.54 gears, 33" BFG AT's, bucket seats and custom console. Final assembly, nearing start up...
"Those who hammer their guns into plows will plow for those who do not."
~ Thomas Jefferson
"America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves."
~ Abraham Lincoln
~ Thomas Jefferson
~ Abraham Lincoln
- Craigerf100
Well spring and summer hit and I'm finding many things to fill up my spare time with. My bump isn't one of em. So the engine is still head-less but I've got a few things here and there done. Like rear tail lights working on the "new" bed. A new brake light switch. And this:
A shiny new brake booster. I'm just test fitting it in this pic. But it's gonna stop way better then my old remand one.
But yeah all I need to do is install the heads and the engine "should" be ready to roll. God willing
- Craigerf100
Got the booster all set up. Installed the brake rod to the brake pedal, booster bolted down, MC re installed and I spliced in the adjustable proportioning valve until I buy and install rear disc brakes.
The update on the engine is that I've got the new head gaskets installed, heads torqued down and valves/rockers adjusted and torqued. And also the headers and exhaust re installed.
Since I've got the intake and valve covers off I'm buying a new shiny high rise intake and new shiny valve covers cause what was on it were used free to me refurbished intake and covers.
I also installed a lokar kick down cable and fuel pressure gauge.
I'm planning to ditch the oem fan and install an electric one. Also header wrap, and new plugs n wires.
- sykanr0ng
[quote="Craigerf100"]
So driving my black 68 f100 short bed style side Friday, and this white chevy blazer swerved right in front of me, trying not to clip the car in front of 'it' while on the highway. i tried to avoid hitting it but both of us ended up sliding out of control along the highway. the blazer missed the guard rails.... but my truck didn't. i hit them probably going 50mph. it spun me around then the back end of my truck it the rails. and thats what stopped me. by the time i got out of the truck the blazer was long gone....
And that right there is why dash-cams are becoming very popular.
... I've got skills, ingenuity and no regard for maintaining any kind of historical preservation/authenticity...
- Craigerf100
Yep, I may get one now.
- Craigerf100
So these are the new parts I'm planning on buying next week for my 302. I wanted these originally but could afford them at the time. But since I had to install new head gaskets, I might as well install new intake and valve covers.
- Craigerf100
So here's my truck now. I've thought about doing the black out look.
And these are some pics that I found; that are another direction I've thought about going. This is the look my wife likes best.
- Craigerf100
Hooked up my Am radio and (free) pioneer stereo unit up in my truck the others day. Am radio i have the light only hooked up. And the stereo i installed in the glove box. I control it via remote and I also installed a auxiliary cable for my music play lists.
When i was splicing the wires togeather I decided to wire it where I could swop stereos out if and when I get a better unit.
I also de-jerry rigged much of the PO wiring job. :/
It all works well except. It looked better in my head then it turned out . Not sure yet how I'm gonna mount the stereo to the glove box.
So far so good! Looking good. Be sure and update us with what you figure out.
