Lost power to fuse panel!
- Rockybar
I lost power to 3 post of my fuse panel.
The instrument lights, and the two plugs on the left.
The wiring in the truck has been a bit bastardized, but its kinda hard to not find that in 40yr old rigs.
All other fuses have power. All fuses are good
I recently moved the dome lights and volt meter to the top left post, and radio/turn signals to bottom left.
Any ideas would be great.
1967 F100
390, 3 spd on floor
(my first ford, so have patience, I'm a Chevy guy)
390, 3 spd on floor
- tbone6
Re: Lost power to fuse panel!
The common element here is the headlight switch. I would start there.
What year/model is your truck?
t6
1972 F100
1972 F100
- Rockybar
sorry,
67 F100
I was running it last night when I had problems, so you may be on to something there.
I removed the fuse box, and check power behind on it on the incoming wire, no power there, so what ever feeds it took a dump
67 F100
1967 F100
390, 3 spd on floor
390, 3 spd on floor
- tbone6
The feed comes from the headlight switch (see attached drawings). I have highlighted the wires (red) in question. You might try turning the knob full throw several times, sometimes they just get crud on the wiper/coil. Otherwise, time for a new switch...
t6
1972 F100
1972 F100
- Rockybar
TBone6, thanks for your help and awesome diagrams.
Tried what you said but no luck. Looks like a new switch is required.
Thanks again
Thanks again
1967 F100
390, 3 spd on floor
390, 3 spd on floor
- tbone6
- Rockybar
I got it temp fixed for now.
I put the signals and volt meter on the big post off the back of the ignition switch
1967 F100
390, 3 spd on floor
390, 3 spd on floor
- tbone6
Sounds good. That big post is power straight from the battery, no problem using it as long as you don't leave a blinker on overnight by accident. The voltmeter will pull a little current just sitting there, so don't let it sit too long without recharging the battery. Or you could just leave your voltmeter unhooked for now...
*edit for spelling
*edit for spelling
t6
1972 F100
1972 F100
- Rockybar
it was a switch 12v post.
1967 F100
390, 3 spd on floor
390, 3 spd on floor
- Rockybar
tbone, how do you remove the switch? Picking one up today
1967 F100
390, 3 spd on floor
390, 3 spd on floor
- tbone6
Here ya go...
The release button
Instructions (click to enlarge the picture)
The release button
t6
1972 F100
1972 F100
Be gentle with removing that harness plug. Mine was brittle as"all get out".
- Rockybar
Replaced the switch, still don't have any power to that fuse panel as mentioned above.
1967 F100
390, 3 spd on floor
390, 3 spd on floor
- tbone6
Were these lights working before you moved them?Rockybar wrote: I recently moved the dome lights and volt meter to the top left post, and radio/turn signals to bottom left..
t6
1972 F100
1972 F100
- Rockybar
Sure was, yeah I moved them to get them working after I lost the power on the fuse panel
1967 F100
390, 3 spd on floor
390, 3 spd on floor
