I was doing a durasapark conversion and noticed this fuse hold broken and not attached . Where does it go or what is it hooked to?
Identify this wire please
1968 F250 Camper Special 390
1964 Galaxie hardtop 352
1967 Cougar project
1993 F350 Crew cab 5.8
1988 Bronco 5.8 C6
1966 Mustang fast back project
New 1962 Falcon Gasser project
1967 Cougar project
1988 Bronco 5.8 C6
- Heirloom
Re: Identify this wire please
From what little I can tell...it's location & color.....it's either a horn related wire or voltage regulator related wire. Both systems have yellow wires in the factory wiring. It also could be something a PO installed. That's about all I can guess. Check the wiring diagrams here...
http://www.fordification.com/tech/schematics_h.htm
~Heirloom
'68 F250 360, 4 spd Project Thread!
Plans are for a stout 400, C6, 3.54 gears, 33" BFG AT's, bucket seats and custom console. Final assembly, nearing start up...
"Those who hammer their guns into plows will plow for those who do not."
~ Thomas Jefferson
"America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves."
~ Abraham Lincoln
~ Thomas Jefferson
~ Abraham Lincoln
Five bucks says it goes to the amp gauge. There should be a red one with a similar fuse holder nearby. One will be attached to the battery post on the starter solenoid, and the other spliced in where the alternator charge wire and the main cab power wire meet.
Amp gauge does not work. Might be that.
1967 Cougar project
1988 Bronco 5.8 C6
1967 Cougar project
1988 Bronco 5.8 C6
You can't just go by that, because the amp gauge doesn't really move anyways. Check for continuity between it and the yellow wire at the back of the amp gauge to actually test it.
