Won't start !!!
fordkenstein
Won't start !!!
Post by fordkenstein »
I have a 70 with a 351c/c6. I bought it that way. It ran when I bought it, and for a while after. Then it stopped - turned the key, and nothing. I have a remote starter switch - when I hook that up, the motor cranks but won't fire. After looking at the wiring under the hood and dash, I ordered an EZ kit - it's on the way. However, the truck is currently parked on the street in front of our house. I'd like to get it started so that I can put it in the garage to do the re-wire. What do I need to do under the hood to bypass most of the ignition circuit?
Fordkenstein
1970 Ranger XLT LWB (Size Matters!)
351c / AOD / 9in
Lowered!
Re: Won't start !!!
replace the ignition switch. the reason i says that is . i figure you may not have had the switch turned on when doing the remote start button. but if you did then it could be the plug is loose on the back of the switch. or the spade terminals in the plug could be loose and not contacting the ignition switch spade terminals.
the red wire coming from the solenoid goes to the ignition switch. when the switch is turned power is sent through the switch to the red wire and makes the solenoid actuate. the brown wire from the solenoid gives a full 12 volts to the coil when cranking the engine over.
fordkenstein
Re: Won't start !!!
PM sent.
Fordkenstein
351c / AOD / 9in
Lowered!
Re: Won't start !!!
do not pm tech problems please.
fordkenstein
Re: Won't start !!!
Okay, but I saw in another post where some folks wanted to keep answers to questions like mine private.
Fordkenstein
351c / AOD / 9in
Lowered!
fordkenstein
Re: Won't start !!!
Hi Fordman,
I had the key in and the switch on attempting remote start - I got nothing. All the wiring in the truck looks terrible, so I bought a wiring harness:
Product : Quantity : Price
EZ 21 - 18 Fuse 21 Circuit-COLOR : 1 : 185.00
I just want to get my truck off the street and into the garage without having to push it up the driveway. I saw this in another post:
Power to the + side of the coil
- side of the coil goes to dist
Will this work? My distributor is wired to the + side of the coil now along with a red and a blue wire coming from ???. There is also a red wire running to the - side of the coil ??? I can't wait to rip all of that garbage out and start fresh with the EZ harness. But I'd also rather not re-wire my truck in the street in front on my neighbors and the dreaded HOA!
Fordkenstein
1970 Ranger XLT with all the XLT trim stripped off :-(
and a 351c under the hood
Fordkenstein
351c / AOD / 9in
Lowered!
mr_josh
Re: Won't start !!!
Post by mr_josh »
What kind of ignition system do you have on your motor? Points or electronic? If the latter, Duraspark or 3rd party?
Josh
'72 F-100 Sport Custom 4x4
fordkenstein
Re: Won't start !!!
Points.
Fordkenstein
351c / AOD / 9in
Lowered!
fordkenstein
Re: Won't start !!!
Here's what I'm dealing with...
Fordkenstein
351c / AOD / 9in
Lowered!
Re: Won't start !!!
you just have to test and see where power is or isnt going to or coming from. it you have power from the switch to the coil it should start.
fordkenstein
Re: Won't start !!!
You were right Fordman - the ignition switch, upon closer inspection, is toast (cracked, burnt, a piece missing, lose wires, etc. I'm going to order a new one from LMC. Any comment on the under-hood hotwire suggestion?
... and use my remote start switch to get her running and off the street
Fordkenstein
351c / AOD / 9in
Lowered!
Thunderfoot
Re: Won't start !!!
Post by Thunderfoot »
fordkenstein wrote: Power to the + side of the coil
Yes, just run a wire from the battery (+) to the (+) side of the coil and use your remote starter switch to get it fired up, you just don't want to run it this way for very long as it is hard on the points but will be fine to move it into your garage.
fordkenstein
Re: Won't start !!!
Fired right up. Thanks! :D
EZ harness should be here Tuesday night.
Hopefully, the switch (and some other goodies) will be here from LMC next week too.
I'll start on it next weekend.
Any tips for my re-wire project?
:fr:
Fordkenstein
351c / AOD / 9in
Lowered!
