long or short??
Junior Knight
long or short??
Post by Junior Knight »
The stop lites on my 67 quit...bad fuse..it takes a 20 amp but can't find the right size at part stores.
All the 20 amps are to long for the fuse box..any help?
1967 Ford F-100...goin back *STOCK*..just sayin
Re: long or short??
you may have to try hardware stores and other places until you can find one. until then you can put gum wrapper foil over the fuse so it will work until you get another fuse.
70_F100
Re: long or short??
Post by 70_F100 »
AGC20 and SFE20 are different lengths, but offer the same amperage rating.
I think (and I could be wrong) that the AGC20 is the shorter of the two.
Somebody correct me if I'm wrong, please!!!
forrestbump
Re: long or short??
Post by forrestbump »
70_F100,
For what it's worth, I just measured a SFE20 fuse, and it's 1-1/4" in length. Sorry I don't have a AGC20 to compare it to.
Larry
Junior Knight
Re: long or short??
thanks guys...I put a 14 amp in it till I find a 20 that will fit..
70_F100
Re: long or short??
Post by 70_F100 »
OOOPPPPPPSSSSSSSSSSSS...
The 20-amp fuses are the same length in AGC or SFE.
All AGC fuses are 1.25" long.
The SFE20 is the same length.
SFE fuses are longer or shorter according to amperage rating.
Sorry for the misinformation!!!
Junior Knight
Re: long or short??
then..why can't I get the reg. fuse in the same spot? Its the orig. fuse box...
70_F100
Re: long or short??
Post by 70_F100 »
The 14A fuse is the correct fuse. AFAIK, all of the fuses in these trucks used SFE fuses, which changed length based on protection rating (amps to blow).
From your other post about the headlights, I have to believe you have a short somewhere.
Junior Knight
Re: long or short??
thanks!
borderlinehero
Re: long or short??
Post by borderlinehero »
AGX 20 will fit. They are 1" long.
