hot wire
timmytim
hot wire
Post by timmytim »
Has anyone ever ran a hot wire from switch to underhood fuse block or relay for acc? Im going to add several hot wires that turn on with switch but i dont want to keep having to run a wire to the switch :?
:fr:
buy'em dirty sale'em clean
get more money for the same
machine.....
:loco:
My 1967 bump: http://www.fordification.com/forum/view ... 09#p668209
My 1970 Bump: http://www.fordification.com/forum/view ... 16&t=50726
Re: hot wire
some years of trucks have two extra posts on the fuse box for extra power out. but running one power wire to a new fuse box under the hood right off the positive battery cable would give you a place to hook up power to switches.
390Nut
Re: hot wire
Post by 390Nut »
Check the wiring diagrams here on the board (links at top in the factory literature, I believe).
I found a blue wire under my dash that went nowhere, with a butt receptacle on the end. I found it was hot with the ignition switch on, and this is what I used for a trigger to the relays I used for my ignition; MSD and Pertronix, two relays (one for each item) so I didn't have to worry about the resistance wire or bypassing it. Been quite awhile since I discovered it, but if I remember correctly it is a full 12V source.
Paul
`69 F100 390 4spd driver
Pipes71 did once say, "bumps and bikes.. what a great combo!" :thup:
timmytim
Re: hot wire
Post by timmytim »
thanks guys :thup:
:fr:
machine.....
:loco:
BobbyFord
Re: hot wire
Post by BobbyFord »
Buy an aftermarket fuse/relay block, wire from the battery and plumb your circuits.
timmytim
Re: hot wire
Post by timmytim »
if i wire from battery whatever i hookup will be hot all the time right?
:fr:
machine.....
:loco:
Caseys71
Re: hot wire
Post by Caseys71 »
timmytim wrote:if i wire from battery whatever i hookup will be hot all the time right?
Correct, as long as you're wiring directly from the battery it is a constant hot.
Casey
16 years old with a 40 year old truck (well almost)
1971 F-100302, T-18 4 speed, 3:55 rear, & an Edelbrock sticker on the ashtray.
"Don't worry about what you become, just make sure that you're successful at what you do."- Mr. English
"Value what you DO have over that which you don't."- Forrestbump
"Wanting can sometimes be better than having, never stop dreaming... it's what keeps us all going."- Forrestbump
1984 Toyota 4x4: 22-R, 5-speed, 3" suspension lift, 35's and 5:29's
timmytim
Re: hot wire
Post by timmytim »
im need a hotwire thats only hot when switch is on
:fr:
machine.....
:loco:
BobbyFord
Re: hot wire
Post by BobbyFord »
You can run a relay to power something whereas the relay is switch by the ground wire.
timmytim
Re: hot wire
Post by timmytim »
say that one mo gan?
:fr:
machine.....
:loco:
Boydc1971
Re: hot wire
Post by Boydc1971 »
I used a four circuit fuse block from Painless Wiring . I believe you can get as many as 20 circuits if needed. Weatherproof models if needed. i just ran one hot one from the switch and branched off from the fuse block to obtain as many switched hots as needed.
Hemmi06
Re: hot wire
Post by Hemmi06 »
I am on the same boat as you and this is my current plan: :drive:
This part: http://www.summitracing.com/parts/PRF-70207/
I am going to excite the relay on this fuse block from either the Emergency Flasher or the Gauge fuse terminal on the Bumps fuse block. The reason I am using these is they are on with the key in ACC but also still hot at START. :2cents:
I plan on fusing some ignition stuff here so it would suck if I turned the key and it would not have power!!
1971 F250 Camper Special
360cu with RV cam and 4v Carb
timmytim
Re: hot wire
Post by timmytim »
Thanks guys
:fr:
machine.....
:loco:
