Some identification help please
Gaslight
Post by Gaslight »
So over the weekend while doing a master cylinder on my truck I discovered this jumper tucked up and out of the way. I have not looked into running the wires down yet. But the jumper almost looks factory.
Anyone able to ID what is happening here?
Thank you
Jake
1969 F100 Ranger
cep62
Re: Some identification help please
Post by cep62 »
If you have a manual trans it might bypass the neutral safety switch.
Gaslight
Post by Gaslight »
No manual. 360 with a C6. I am hoping to get the chance in the next day or so to trace wires. But its a mystery.
Jake
1969 F100 Ranger
DuckRyder
Post by DuckRyder »
Have look here:
https://www.fordification.com/tech/schematics_h.htm
Fairly sure that the backup light harness for a manual.
Gaslight
Post by Gaslight »
Thank you. I did not get a chance to investigate further last night. But I will take a look there first.
Jake
1969 F100 Ranger
Jen71rangerxlt390
Post by Jen71rangerxlt390 »
So I have the same wire that came out of my truck. I have the same engine and transmission as you also (automatic C6 360/390). My neutral safety switch has been taken out of play for quite some time now and I am in the process of rewiring a lot of things; mainly my exterior lights, some burnt up ignition wiring and everything in the engine compartment. But that is factory and it is to do with your neutral safety switch, I do know that much. Since I don't have my stock wires still in place, please update the post when you do figure out where they go to exactly. Pictures help a bunch. thank you
