Adding PS. Pulley question
I am adding PS to my '71 F100 with 302. It does NOT have AC. I was given a 3 groove crank pulley but it actually touches the water pump pulley (inside one of the grooves). Seems like it should have a shim or something behind it to move it forward. Will a 3 groove work? Or do I need to find a 2 groove?
Re: Adding PS. Pulley question
Not sure if this will help, but this thread has some info in it, click on the link there and it goes to crank shift pulley numbers, at the bottom of that page it has a section for pulley crankshafts (small block 302). http://www.fordification.com/forum/view ... =5&t=80384
Hope this helps!
Hope this helps!
