Can someone please tell me what might be wrong.
My instrument panel does not light up.. I’ve changed the fuse, all the bulbs and still no lights
Need Help
72 Ford F-250 sport custom
Instrument panel
Re: Instrument panel
It might be a bad fuse or a bad headlight switch. There is a spring like piece in the headlight switch that may be bad? Do you have the headlight switch control knob turned up all the way? It controls the dim or bright of your instrument cluster lights. Just some suggestions to check on.
Let us know what you find out!
Regards![Thumbs up :thup:](./images/smilies/icon_thumright.gif)
Regards
Yes I did turn the knob all the way. And I did buy a new switch but I guess it could be bad. Also I did try two different fuses still no luck.
Thank you for the reply
The list of "what might be wrong" is endless. It's time to get a test light and the wiring diagram and see where voltage should be and where it isn't. It's a very simple circuit and it should only take a few minutes to pinpoint the problem and learn a thing or two in the process. ![Laughing at previous :lolprev:](./images/smilies/icon_laughing4.gif)
1967 F-100 4x4 custom cab.
not sure about this but I think if the tail light fuse is bad, it also kills the instrument panel lights as a warning. just a thought
- 1972hiboy
Busboy wrote:The list of "what might be wrong" is endless. It's time to get a test light and the wiring diagram and see where voltage should be and where it isn't. It's a very simple circuit and it should only take a few minutes to pinpoint the problem and learn a thing or two in the process.
![Yeah that :yt:](./images/smilies/icon_yeahthat.gif)
Rich
Dont eat yellow snow.....
- sparky72
It's possible that you have corroded fuse contacts in the fuse block.
Taylor
1972 F250 Ranger XLT 2wd / 8100 GVW / 390 / T18 / 3.73 D60
Found the problem it was a broken wire in the printed circuit board.
Thanks to everybody
Thanks to everybody
