Brake system light
Brake system light
The little light for the brake valve differential indication...is there a secret to removing that lil' *******?
""Never shoot a large caliber man with a small caliber bullet."
2017 Ford Raptor
1948 Willys CJ2A w/ Ford Flathead V-8
1975 Ford Bronco
2017 Ford Raptor
1975 Ford Bronco
- Canonman67
Re: Brake system light
Push in on the back and turn. It's held on by spring tension.
Are you talking about the bulb or the entire assembly? I should have specified but I wanted to remove the entire assembly.
2017 Ford Raptor
1975 Ford Bronco
2017 Ford Raptor
1975 Ford Bronco
- Canonman67
The entire assembly. It's only three pieces held together with spring tension. Front bezel, spring and lamp socket.
Thank you, I'll give it a try tonight. I've got to pull an all nighter to get ready for my up coming night shifts, I'll see if I can get the damned thing out.
2017 Ford Raptor
1975 Ford Bronco
2017 Ford Raptor
1975 Ford Bronco
