Brake lights backwards
cewilson19
Post by cewilson19 »
So my brake lights have been troubling me now for awhile. I have replaced fuses, brake switch, headlight switch and turn signal switch. All lights work even the brake lights but not correctly.
When I attach the wires to the brake light switch I see sparks as the second ones makes contact. Once both connectors are on the brake lights turn on. If I press the pedal they stay on but once I began to release the pedal they turn off. So doing the exact opposite of what I need. So I'm figuring somewhere along the way...maybe with the turn signal switch Ive done = something backwards to create this problem..
Any ideas?
Thanks
Chris
Canonman67
Re: Brake lights backwards
Post by Canonman67 »
It sounds like you've got a hot wire feeding all the time after the brake switch. You're going to have to retrace all your wires to see where it's coming from.
cewilson19
Never mind. It seems our getting jammed on the brake pedal. Like I'm missing a piece. If the spring gets pushed it does not completely reset. Seems I should have a spacer or something In between the the brake pedal and the switch.
