Printed circuit connection
WarEagle
Post by WarEagle »
Hey all,
I am doing a total rewire with a kit from Painless and need some help.
I'm looking at the schematic found here in the site for a '72 F100 custom. It shows the factory printed circuit connector wires for the instrument panel, but it does not match up to mine. The schematic shows 12 possible connection points with 9 wires. My truck has the same 12 point connector but has 11 wires, and the location of the color coded wires are not matching the schematic.
I realize the 2 extra could have been added at some point, but I was wondering if I am looking at the right schematic in the first place. Is there another resource for instrument panel wiring? :?
Thanks and Happy New Year!
1972 F100 300 cid straight 6
2009 F150 4.6L Super Crew
Busboy
Re: Printed circuit connection
Post by Busboy »
I thought they claimed that it was painless? :wink:
1967 F-100 4x4 custom cab.
two-bit
Post by two-bit »
Do you have the full gauge package in your truck? ie: amp, oil, fuel, temp.
Or warning lamps for oil and amp?
That may be the difference. I know the amp gauge and the amp warning light use different wiring in the harness. Maybe it is different also at the plug to the cluster? Just a guess?
Let us know what you find.
Two-bit
Living life full throttle on the North Coast of America!!!
72' F-350, DRW, 360, NP435, Dana 70, 159" WB, P.S., P.B., 12' flatbed, 10,000 GVW.
two-bit
Post by two-bit »
Check out the 72' master wiring legend....
Look at the connector legend page. Close attention to C-49 and C-10.
I think this may help you out.
http://www.fordification.com/tech/wirin ... legend.jpg
Two-bit
WarEagle
Post by WarEagle »
two-bit wrote:Check out the 72' master wiring legend....
Two-bit
COOL - Thanks!!! It does match to C-49. I have the oil and alt lights, not gauges. Where does that fall into the bigger schematic? I thought at C-49 but I couldn't find the connector like the '72 quick reference diagram has. I need to see where all the wires go to.
WarEagle
Post by WarEagle »
Busboy wrote:I thought they claimed that it was painless? :wink:
LMAO, I know right? So far so good though. The kit is labeled really well, just having trouble on the Ford side of things. :thup:
Ranchero50
Post by Ranchero50 »
Trace the foil to see where the connections are going and deduce what needs hooked up from there. I'd much rather restore a factory harness vs. deal with an aftermarket one.
WarEagle
Post by WarEagle »
Ranchero50 wrote:Trace the foil to see where the connections are going and deduce what needs hooked up from there. I'd much rather restore a factory harness vs. deal with an aftermarket one.
I know what you are saying, but there were too many splices and hanging wires. The ignition worked but not much else. Also, I decided to go aftermarket because of the extra circuits available, elec choke, elec fan, power antenna, cargo light, accessory, etc....
The issue i'm having is just making sure I am connecting correctly. I am doing the tracing but wanted a reference to confirm everything. I don't want to add power and blow some fuses!
sargentrs
Post by sargentrs »
This is about as detailed as it gets. http://www.fordification.com/tech/wiring_1972master.htm Page 5 is the instrument cluster master diagram. Connector chart may be of some help too.
WarEagle
Post by WarEagle »
OK, I'm hoping the answer to this question is as simple as I think. Basically, the only wires that are repeated in multiple circuits would be the red and black. Meaning, for example, the red-blue goes from ignition to starter relay. that color combo should not be used anywhere else on the truck. Therefore, because the C-49 schematic is not shown in the master, I can follow the color coded wires that are in the connector to know where they are supposed to go (and come from).
Is that a safe assumption? :hmm:
Ranchero50
Yes and no. Ford has been very good about keeping the wire number and color consistent throughout the years. When I did my wiring integration for the diesel swap I wrote down the from - to of each wire, it's color, number and purpose and it worked out well.
