I am getting close to needing my wiring harness. I am running EFI, A/C, electric fan maybe down the road PW and PL. I originally thought about getting one of the generic reasonably priced 21 circuit kits for $200 or so. Then I began to dig into actual Ford kits. Ron Francis has a nice kit for $389 but does not have provisions for PW and PL. Centech has a very nice kit and is custom tailored to your setup and it is mostly plug and play. It has enough circuits for everything I need and it's around $450. So what is your experiences and what did you use?
Barry
Wiring Kit Brand
Re: Wiring Kit Brand
I used EZ wiring 21 circuit on my Highboy. If you have the plug ends from your old harness and some time it may be worth the savings. Not for sure about what extra you need for EFI though. I purchased connectors from Wayteck. The color wiring diagram from classiccarwiring.com was a bunch of help.
For my Camaro I used American Auto wire which was plug and play. It was expensive, but I didn't have any of the plug ends. Even though it was expensive it was nice and easy. I'm guessing that would be the case with the Centech.
