Condenser to coil?
radioactivelarry
Condenser to coil?
Post by radioactivelarry »
I removed my carb today and found there was a normal looking condenser attached under the carb bolt and the condenser wire went to the plus terminal on the coil. Not factory! I think this is an attempt to suppress static to the radio? Am I right? Does anyone know for sure?
Thanks all,
Democracy is two Wolves and a Lamb voting on what to have for lunch. Liberty is a well armed Lamb.
Ben Franklin.
My Motto: I wish I had less to do, more time to do it in and got paid more for not getting it done.
:drive:
radioactivelarry
Re: Condenser to coil?
In other words there is a condenser (capacitor?) from a grounded engine bolt and goes to the plus terminal of the coil. If the cap shorts out would this ground the coil making it inoperative or other problems?
I think the PO added this for radio static suppression but not sure.
Thanks for looking,
Ben Franklin.
:drive:
Yes it is for the radio.
