Hey Guys, I'm wanting an under hood [ignition on]12v distribution block for accessories now and future. Id like to have power for the tach, electric choke, etc. from this block.
Question: Is the a wire at the alternator or regulator where this is possible, rather than trying to tap in behind the ignition switch?
I had an unconnected wire that laid on my intake alongside my valve cover on the driver side. It was either orange or brown, I can't remember, with a female bullet connector on the end. It went to some option I didn't have, the carb solenoid connection (see pic from wiring diagram). Turned out to be 12v switched. I always eyed it as a potential accessory connection in my engine bay.
Will this switched source work to hook up ann electric choke? I have read the choke should be connected to the alternator stator because that connection will put out less than 12 volts.
The electric choke I put on mine was spec'd at switched full 12v. Autozone special.
sargentrs wrote:The electric choke I put on mine was spec'd at switched full 12v. Autozone special.
Mine is hooked up in like manner.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
the easiest place to tap it is on your coil (+) wire, but you might end up with issues if you start drawing a lot of current right through the ignition switch.
if you want to have lots of power for multiple accessories, best thing is to pull that wire from (+) coil and hook up a relay to deliver fatty current to the fuse block.
I found some nice Hella brand universal mount AGM fuse blocks, but none of them have built in relay sockets which i think would be real handy.
i'm going to end up cobbling something together myself.
I'm a firm believer in not wiring up accessories into our wiring harnesses without using a relay. you are looking for problems later on. "ignition switch, Headlight switch and wiring burning up". Here's a pic of my setup. powered Fuse block wired of my battery decent gauge wire don't remember the gauge. one relay is for my ignition and the other is for my radio. I also use the LMC headlight wiring harness for the headlighs relayed high and low beams off this fuse block. These trucks were designed for the technology of the time.
motzingg wrote:the easiest place to tap it is on your coil (+) wire, but you might end up with issues if you start drawing a lot of current right through the ignition switch.
From what i hear you're not suppose to use power supplied to the coil, the coil need all it's power, and apparently some coils use 9v instead of 12.
69Ford wrote:I'm a firm believer in not wiring up accessories into our wiring harnesses without using a relay. you are looking for problems later on. "ignition switch, Headlight switch and wiring burning up". Here's a pic of my setup. powered Fuse block wired of my battery decent gauge wire don't remember the gauge. one relay is for my ignition and the other is for my radio. I also use the LMC headlight wiring harness for the headlighs relayed high and low beams off this fuse block. These trucks were designed for the technology of the time.
Excellent set up! I hope to post some pics soon. I had to buy some brass fittings for the sender I am going to use.
There are two types of coil's. Resister coils and non resister coils. At least in the 69 model year ford used the non resister coil that's why there is a resister wire to bring down the voltage to an acceptable voltage for the points. I believe between 6 and 9 volts so this would not be a good point for accessory's I also believe this is for all bumps but not sure. Also if you leave the key in the on position without the truck running the points and coil will be damaged and good chance your accessories to. The ignition switch in the ACC position will shut your accessories off if wired to the coil. The only time the coil has 12 volts is when the ignition switch is in the start position starter turning. I know to much info to think about.
Here is what I am doing. Using a oil switch activated by pressure to get 12 running volts. Brass t-fittings and other parts used for adding the switch to the original one.
Wiring assembly will provide 12 volts only when engine is running.I am going to attach the coil and the tach here.
Just fits between pumps and under brackets.
[/quote]There are two types of coil's. Resister coils and non resister coils. At least in the 69 model year ford used the non resister coil that's why there is a resister wire to bring down the voltage to an acceptable voltage for the points. I believe between 6 and 9 volts so this would not be a good point for accessory's I also believe this is for all bumps but not sure. Also if you leave the key in the on position without the truck running the points and coil will be damaged and good chance your accessories to. The ignition switch in the ACC position will shut your accessories off if wired to the coil. The only time the coil has 12 volts is when the ignition switch is in the start position starter turning. I know to much info to think about.[/quote]
yeah good call... i'm running Duraspark and forgot that some trucks have the ballast resistor on the PINK wire in run.
