70 f100 turn signal issues
Put a new flasher in and still don't have signals. Emergency signals work fine just the blinkers are all dead. Any pointers on where to start looking? Thanks
Re: 70 f100 turn signal issues
Aren't there two flashers? One under the dash for emergency and one behind the instrument cluster? Could also be the turn signal switch. http://www.fordification.com/tech/image ... l_7072.jpg
Yeah there are two flashers. Both are new. I guess I need to trouble shoot the switch
Also, it looks as if I tap it right out of the light switch that I am getting it before it's fused. Is that the case? If so I probably ought to add a 2A fuse in my line to the gauge light, correct?
"M Better"
- tbone6
Sorry, but I am a little confused. Are you talking about tapping the light switch to use for the turn signals or the gauge lights, or both?mbetter95 wrote:Also, it looks as if I tap it right out of the light switch that I am getting it before it's fused. Is that the case? If so I probably ought to add a 2A fuse in my line to the gauge light, correct?
Yes, it will be unfused if you use the wire at the ign. switch.
t6
1972 F100
1972 F100
- tbone6
Here is the simplified version of the turn circuit power.
I would start at the fuse, then work my way to the flasher, then to the switch.
t6
1972 F100
1972 F100
