72 HiBoy,
I have done a little reading....shop manual and on here.
If my understanding is correct the IPVR also effects the oil pressure gauge, temp, and fuel....? My oil pressure gauge, I am not going to say its correct but it seems to reading believably positions, well over center while pulling and a little below when warm and idling.
With this said my Temp and Fuel both seem to be reading on the low side.
When I test the IPRV it the light pulses my guess would be at 2-3 pulses a second....however and i have no scientific proof just from what i thought i saw, i am not sure if it was constant flash. (this may have been influenced by a case of PBR)
Second when i ground my fuel gauge out it registers full.
Thus should i adjust the IPRV as described in
http://www.fordification.com/forum/view ... on#p586290 I would hate to adjust the IPVR so that my fuel gauge reads correctly...but then find out in un pleasant cercumstances that my Temp, and Oil readings have been wrong.
Anyway...thoughts?
Thanks
Rob
