Truck when I first got it:
After bead blasting:
Found a lot of rust and bad repair jobs after bead blasting so next up was to sand blast the bad rust and DA the rest.
This is after the metal repair:
Now on to repair the 47 dents that was found then epoxy primed.
After epoxy primed along with a guide coat for block sanding:
Couple of photos on the interior before paint:
