Can anyone help me with this issue or issues?
My 1969 Ford F100 pickup 360, Will Crank and then it will shut right off as soon as I release the ignition switch key. A few times the starter kept on going so I had to disconnect the battery every time. This all started happening when i rewired my ignition switch because the wires were just stripped bare(I thought I put them all back correctly?) Does anyone have a wiring diagram for this for pick up on the ignition switch.
Because of this issue I have replaced the starter, and the solenoid...One thing I have noticed is that every once in a while the solenoid has power on the "I" side when I take the Brown wire off the "I" side it still has power, until I cycle the keys on and off?
I will be replacing the ignition switch tonight. Although I just want to be sure it isn't the wiring.
Thank you in advance for your help...
