1968 f350.
On the run position of the switch there is a pink (coil resistance) wire and a red with yellow stripe wire. I can't find that red/yellow wire in any of the schematics. Anybody know where it goes?
Where does this wire go?
- knightfire83
Re: Where does this wire go?
1970 Ford F250 4x4 ~ Sold.
- ta TACO
http://www.fordification.com/tech/wiring/68-09.jpg
I believe it supplies power from the solenoid to the fuse panel, and links up to a yellow wire going to the ignition switch.
These are 37 and 37A.
Hope this helps,
Davin
Hope this helps,
Davin
68 F-250 CS, 360 or 390?, still haven't measured the stroke, AUTO running on propane!
