Electric fan help...
cole71
Post by cole71 »
I have an electric fan I'm trying to wire up.
The kit I bought has a relay, for the temp thermostat that's screwed into the intake.
Basically, all I need is a switched 12v power source. What is a good wire to splice into? Also, would it hurt if power is sent to it with the key in the accessory position as well?
mrollings53
Re: Electric fan help...
Post by mrollings53 »
I've got mine wired to the coil pin on the ignition switch. There shouldn't be a problem wiring it to the accessory pin either. It will just be able to turn on when the ignition is in accessory as well.
cole71
Post by cole71 »
Ok, thanks. How long have you had yours wired that way? Any problems?
cole71
Post by cole71 »
Believe I found a wire that will work. It's coming off the driver side and is a open bullet connector that has power. Thanks everyone.
