Hi Guys,
I'm installing an "old school" Mallory Dual Point Distributor (2755301) and a Mallory Voltmaster Mark II Coil in my F.E. in my 71 Truck. Do I also need to get some kind of in-line resistor to the coil? I spoke with the mechanic in town, and he said he thought I'd need one. Anyone ever heard of this?
Thanks,
Bob
Coil/Distributor Question
71 Ranger XLT LB 2WD
Tilt Steering, West Coast Mirrors
390, 9.5-1 C.R., Holley 600, D2 Heads, C-6
Custom Grind Oregon Cam
Flotech Headers, 2.5" Duals w/H-Pipe
Re: Coil/Distributor Question
your truck already has a resistor wire from the ignition switch to the dist. if you need a resistor then the original wire will work fine. if not then you can bypass or cut and remo9ve the resistor part of the wire to get a full 12 volts. i would contact mallory to see what they say before i went cutting any wires on your truck though.
