Starter Stuck
- kidd68
Starter Stuck
This morning the starter on my 96 stuck. Turned the key off and the engine stopped but the starter still was cranking. I had to unhook the battery to make it stop.I put it back on and it started and shut off like normal. Where should I start to look?
- DCrusher
- Location: Hurst,Texas halfway between Dallas/Fort Worth
Re: Starter Stuck
Starter solenoid on the passenger fender just replace it it will do it again the contacts are sticking internally.. Follow the + Positive battery cable goes right to it..kidd68 wrote:This morning the starter on my 96 stuck. Turned the key off and the engine stopped but the starter still was cranking. I had to unhook the battery to make it stop.I put it back on and it started and shut off like normal. Where should I start to look?
55 F-100
57 Oval VW
88 Dodge Ramcharger
55 F-100
57 Oval VW
88 Dodge Ramcharger
