As far as I know, there are three condensers. One in the distributor, one on the alternator voltage regulator and one on the IPVR. I made one for the alternator regulator by putting a plug on it instead of the pig tail. I am having alternator problems so I don't know if it works or not. I still need one on the IPVR.
http://www.autozone.com/autozone/parts/ ... umber=true
Has anyone ever done this before? Can I make one for the IPVR too?
Electrical condensers
- bjde0b
Check out my build. http://s1088.photobucket.com/albums/i336/MyF100/
- bjde0b
Re: Electrical condensers
It is surprising that nobody has tried this before.
- Nitekruizer
Just curiuos, why do you want to put a condenser on the IVPR? It's been a while since I've had my dash apart so I can't remember, was there one on the IVPR and is yours missing?
- bluef250
The condensors act as radio noise suppresents and could be removed and the vehicle would still run.
- bjde0b
I know it will still run, but the radio isn't clear. I like the old AM. I have a highligner, too, but I want the radio to work in this restored truck.
The IPVR uses one because I have seen it on here and in salvage yards. When I connect the gauges, the radio pops and clicks, when not connected, it does not happen.
I've been behind the dash of many of our bumps over a 30 year period of working on and driving them and also never seen a condenser mounted onto the back of the instrument panel, (or one advertised for sale for that matter)? Not saying there isn't one-but that I've never seen one, (or even seen one drawn into all the wiring diagrams on our bumps I've studies here over the years).bjde0b on Fri Jan 11, 2013 6:20 pm
Maybe parts monkey over on the dark side knows more about it?
Here's the 67-69 instrument panel drawing:
And here's the 70-72 drawing:
- bjde0b
- 69Ford
Here's a picture of one that was on my truck. Not sure if it is called a condensor or noise surpresser. I hear these go bad so that probaly explains why they are missing on most bumps and also newer style stereo's have them built in.
