Electronic Ignition
LuvMyScamper
Electronic Ignition
Post by LuvMyScamper »
Hey guys,
We're getting a Petronix Ignitor II and Flamethrower II coil installed in our truck tonight. The instructions say to bypass the ballast resistor. In doing some research, I see that some years the trucks had just a fat pink wire from the ignition switch but other years actually had the ceramic box thingy on the firewall. What would our 71 (with a 390) have?
Cindy
1971 Ford F350 Scamper - 390/C6
2004 Jeep TJ - Lifted, locked and trail ready
2015 Hyundai Santa Fe - Grocery getter/gas miser
LuvMyScamper
Re: Electronic Ignition
Can anybody help ASAP? The truck is being worked on right now and there is a red wire with a strip on it that comes off the positive on the coil, no pink wire to be seen at all. How do we find the resistor?
Cindy
TNIceWolf
Post by TNIceWolf »
If you cant locate a ballast resistor on the firewall I would think it would be safe to assume that it only uses the resistive wire.
( edit )..... It will probably be necessary to locate the resistor wire at the switch and trace it from there to see where it drops down to a smaller wire. That should be the part of the wiring that gets bypassed with a " normal " wire
Presently in the stable
1969 Ford F-350 DRW
LuvMyScamper
TNIceWolf wrote:If you cant locate a ballast resistor on the firewall I would think it would be safe to assume that it only uses the resistive wire.
Thanks! I think our friend got it figured out.
Cindy
TNIceWolf
Post by TNIceWolf »
Let us know how it works. I for one have assembled the components for a Duraspark conversion but am leery of trying it out of fear of screwing it up.
1969 Ford F-350 DRW
LuvMyScamper
TNIceWolf wrote:Let us know how it works. I for one have assembled the components for a Duraspark conversion but am leery of trying it out of fear of screwing it up.
Well it's in and they got it started, so far so good! There was a pink wire coming from the ignition switch. He removed that one, and ran a new wire from the switch through the firewall to the coil, and just left the old wire there in case we ever needed to put the points back in. The multimeter battery died so he couldn't verify that he was getting a full 12 volts to the coil, but he's pretty sure he got the right wire.
Cindy
basketcase0302
Post by basketcase0302 »
That would be right Cindy.
Charlie, duraspark is easy. Call me if you want some help with it man. I kept my duraspark distributor from my 30 year collection, (it's here somewhere). But I'll stay with my Pertronix now that I've fiddled with them for so long. :lol:
LuvMyScamper
Good to hear Jeff! :thup:
Cindy
