where to have an ecm for a 4.6L flashed for use in my 67????
sparks427
Post by sparks427 »
as the heading says im needin to have the ecm flashed for my 4.6 so i can use it in my 67 f100, anybody have any ideas as to where to go, i did a whole bunch of research on the subject w/ no luck so if theres a link i'm missin or info i'm not seein send it my way, thanks in advance guys!
2000 powerstroke reg cab 4x4
67 f100 reg cab 2x4
HIO Silver
Re: where to have an ecm for a 4.6L flashed for use in my 67????
Post by HIO Silver »
I'm somewhat confused. Exactly why do you need to reprogram the ECM?
Responding blindly, have you tried Superchips?
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
wasgas
Post by wasgas »
There are a few companys that make a standalone ECU and wire system for them, ACCEL and Ford Motor Sports come to mind. The mustang and diesel guys get it done all of the time, Ford can flash it with the latest but most of them have their heads to far up their a$% to figure out how you could possibly have it in a 67 . Why does your existing one need reflashed?
sparks427
Post by sparks427 »
im pretty much needing hte PATS removed, the emissions and EGR removed and various other things done that i really dont need on my truck. ive seen ppl do it but havnt figured out where they have it done. the detail zone can do it for 350 bucks, but i was kinda hopin i could have it done for less but somtimes in order to get good quality ya gotta pay the money for it i guess. there was just stuff the car had on it and did that i wont need or use on my truck that i need taken out of the ecm to sum it up.
67 f100 reg cab 2x4
wasgas
Post by wasgas »
I think you can make PATS work with the module if you have it and the oem key, but $350 don't sound to bad if it will fix your issues, I think the standalaones are much more.
HIO Silver
Found a source to reflash your ECM from this article describing the 96-03 modulars: http://www.ronfrancis.com/products.asp?dept=292
The Detail Zone is a division of Ron Francis Wiring: http://www.thedetailzone.com/index.htm
Good luck. ~HIO Silver, away!
68 Mustang
65 Mustang
sparks427
Post by sparks427 »
thanks for the responses guys, ya i dont have the original key, and id rather get rid of alot of that stuff cleans up the engine bay that way.
67 f100 reg cab 2x4
