'69 Camper wire harness color code? Need wiring help.
alvald83
Post by alvald83 »
I am getting ready to wire up to a 7 wire round camper plug. My camper special already has the flat 7 wire plug but I intend to replace it with a 7 round plug.
Since my plug seems to be an untouched original plug, I was assuming I could just go by the factory wiring diagram. That's the problem, I can't fing the wire color code. I can find the diagram that's names the color, but nothing that says what it's for. I know I'm being lazy (I could test every wire) , but my connector has about 6" of the harnes hanging out next to the gas tank under the bed, so it's in a awful spot to try to test each.
My plan was to get the color code and cut and splice the new colors and run them up to a easier spot to do my final testing before connecting the new plug. Too bad some one doesn't make a adapter harness. Thanks for your help. Al
basketcase0302
Re: '69 Camper wire harness color code? Need wiring help.
Post by basketcase0302 »
Al,
It's not always gonna be right but here's the color chart. I'd still test each wire just to save from blowing fuses. :2cents:
Kraig
Post by Kraig »
Have to keep this in mind for mine. Thanks for posting.
1969 F100 Ranger LWB Big Block, factory bucket seats and behind seat storage (arrived 3/21/12) (and it was free!)
1986 Thunderbird Turbo Coupe 247K and still going strong! (sold with 251,758 miles on it!)
1986 Comp Prep SVO Mustang (1 of 83) "the original Fox body "R" model!!"
1972 Ford F-100 LWB SOLD 5/2/6
1995 F150 XLT Supercab (wanna trade for a Bump?)
basketcase0302
Your quite welcome Kraig. I'm still a firm believer in these guys too:
http://www.fordification.com/forum/view ... 15&t=66349
bill69f100
Post by bill69f100 »
My dad had the same problem with the 78' 250 that he had. We went to an RV place here locally "Camping World" I think it is. We found an extension 7 pin harness to get the plug into the bed without cutting into the bed. They still might sell them. If your looking at something more permanent. Pull the harness you already have down. See if it will reach the bed side, get a 7 pin plastic male socket and put it in. I said plastic because the metal ones corrode and give you intermittent problems.
