Troubleshooting Charging
olebluecelo70
Post by olebluecelo70 »
Hello. I have a 1970 100 with a 240 that I bought 2 and a half years ago. About six months ago I replaced my alternator, voltage regulator and battery. About two weeks ago My ALT light started coming on. There was no apparent symptom aside from the light. I ride my bike more often during the warm months so after a few days of no driving, I tried to start the truck and got cranking from the starter, but no ignition. The cranking also slowed indicating loss of battery power. When my wife got home I used her car to jump it, and while the starter cranked with full force again, still no ignition. I pulled my spark plugs and cleaned them and afterwards was able to achieve ignition. I was able to start it again once, before The battery was drained again. Today I tried to jump it again, and again had trouble getting fire. I pulled the distributor cap and cleaned the corrosion off the contacts and gently cleaned the contact points on the rotor. By chance I touched the housing of the ignition coil and felt it was hot. after cleaning the distributor, I was able to achieve ignition, and a voltmeter reading at the battery was about 13.5, which is congruent with test results from when I replaced the alternator before. I'm not an expert mechanic, although neither am I incapable, but I'm not sure what all this means. I think it's obvious I need to perform a tune up, but is there something I'm overlooking?
basketcase0302
Re: Troubleshooting Charging
Post by basketcase0302 »
Stop by the welcome mat when you get a chance:
http://www.fordification.com/forum/viewforum.php?f=1
I'd say there might be two different issues here. First I'd put a load tester on the battery, (any discount/advance/pep boys/oriellys will do this for free). It also sounds like there might be a dead short somewhere causing the battery to drain, (one way to search for this is to pull the fuses one at a time).
Then I'd check the voltage at the + on the coil wire, (have your wife turn the switch on and off-you don't want to leave the switch on for long). With the original resistance wiring in place I believe you'll see somewhere around 8-10 volts-12 volts here will fry the points in a short time. Any less than 8 volts says your resistance wiring might be shot-time to run a new wire from the ignition switch. Then I'd try to look for fireworks under the hood at night, ("pot calling the kettle black here") as i just had an issue with my coil a few weeks ago. :doh:
Any hairline crack will cause the coil to short out causing those symptoms. Throwing a new coil and new points on it is usually good cheap troubleshooting IMO that's also equivalent of tuning/performance work. :2cents:
olebluecelo70
Thanks for the input. I'm hoping the rain here will break soon and give me some time to work on it later this week. I'll post again once I've had a chance to try your suggestions.
