Anyone else have this issue?
So, if I touch two wires together I can start my engine. I did replace the starter solenoid, and I have checked all of the fuses. The problem is that I no longer have lights, blinkers or anything, no brake lights nada. I turn my key nothing. All I was doing was replacing an aftermarket volt gauge that someone else had already replaced. If two wires did touch I would not know. Anyone else have this problem?
- 1970 Hi-Boy
- Location: Middle Tenessee/Northern Wisconsin/wherever else I may roam to try and make a buck.
Re: Anyone else have this issue?
Check the fuse-able link for damage.
1970 F250 Sport Custom 4x4 360 V8, otherwise known as the Hi Boy, and a Harley-Davidson.
1953 Lincoln SA200 portable welder with a 4 cylinder 1941 Continental F162 engine.
"If you think you can do a thing or think you can't do a thing, you're right." Henry Ford
