Basic run stand wiring diagram
fomocoguy
Post by fomocoguy »
So, I am closing in on firing my 300 build on my home made run stand and need to build a basic wiring harness to run her and break her in. I am not great with wiring, so I was hoping some of you may be able to give me some info. All I'm going to use is a starter solenoid, coil, duraspark controller and dizzy, an ignition switch, and a fresh battery (no charging circuit). I have a full wiring harness to harvest the parts from. So, my main question is which wires will I need from the controller and where will they go? I think I'll only need a couple of them but I'm not sure which ones....
Joe
1971 F100 flareside 8ft
2006 Dodge Ram 2500 cummins
2005 Ford Ranger
71PA_Highboy
Re: Basic run stand wiring diagram
Post by 71PA_Highboy »
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
fomocoguy
Post by fomocoguy »
Thanks! So let me clarify; you only need two wires to the duraspark? I saw start power and constant power. I aussume the colors you used corrospond with the actual wires to use?
Joe
2005 Ford Ranger
71PA_Highboy
Duraspark has 6 wires IIRC, but the others go to coil or dizzy...
Colors were used just to ID the different feeds and have no bearing on reality....
Got Ford?
1 Lincoln Mark VIII
fomocoguy
Post by fomocoguy »
Got it. Thanks for the help! I'll let you know how it turns out.
Joe
2005 Ford Ranger
