Oil Light Problem
- 67F100-390
Oil Light Problem
For some reason my idiot light for the oil pressure is backwards. When the key is on(engine not running) the light is off, and if the engine is running the light comes on. Anybody know what causes this?
67 F-100 Custom Cab Short Bed
428ci 4 speed
Finally runs and drives after 14 long years in a field
428ci 4 speed
Re: Oil Light Problem
Make sure the sending unit is grounded well, (not too much sealer or teflon tape on the sending unit). Could also be the sending unit itself. Unhook the wire from the sending unit to verify if the light goes out.
The truck originally came with an "idiot light" didn't it-not a gauge in the panel?
- 67F100-390
It has always had the idoit light. For some reason it quit today and is working normaly now. My guess is the sending unit.
428ci 4 speed
428ci 4 speed
- 70_F100
With idiot lights, the sending unit breaks the ground circuit when a specified pressure (IIRC, it's about 6 PSI) is reached, thereby turning the light out.
On the other hand, the sending unit for gauges has a variable ground that is calibrated to pressure. When the pressure increases, the resistance to ground is varied, causing the gauge to change in direct relation.
If you had just changed the sending unit, my guess would be that you got the wrong one. But, since it sounds like nothing has been changed, you could, very well, have a bad sending unit, or possibly just a loose connection somewhere.
That's not an oil leak
