67 F100. The previous owner installed an under dash ammeter for some reason. Maybe the stock one wasn't working. In any case, I pulled an ammeter from another 67 at the junk yard and want to disconnect the aftermarket ammeter. The pic shows what the p.o. did with the wiring at the solenoid (2 red wires). If I simply remove those wires (2 red) and reconnect the yellow and red (from wiring harness) and black wire (to voltage regulator) to the solenoid positive terminal, will that be correct? I don't want to fry anything with my ignorance.
Thanks guys.
Help with wires to starter solenoid
Re: Help with wires to starter solenoid
Bump....anybody? I'm ready to fire up the truck. I'm removing the aftermarket ammeter. Just want to make sure I get the wiring to the solenoid back to the way it should be.
thanks
thanks
- 71PA_Highboy
http://www.fordification.com/tech/wirin ... gauges.jpg
I think your going about it correctly, but without knowing what is happening under the dash I really wouldn't want to commit to anything...
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
1 Lincoln Mark VIII
Thanks. I've looked at that schematic also. That's what worries me. it doesn't match what I currently am seeing at my solenoid.
Anyone else out there with a '67? If so, can you tell me if the wires at your solenoid look anything like mine, and how mine should be connected?
- 71PA_Highboy
Look at the other years as someone may have replaced the wiring harness.
Got Ford?
1 Lincoln Mark VIII
1 Lincoln Mark VIII
