Ballast Resistor
Ballast Resistor
I'm rewiring a '68 Camper Special, F250 w/390. Truck was recently completely pulled apart and repainted. Installing a new harness from Painless Performance. In the kit they included a ballast resistor with instructions to install as part of the ignition. Looking through the original harness and pictures of the engine bay prior to teardown, I can't determine if/where the original ballast resistor was located. Any help would be appreciated.
- 1970 Hi-Boy
- Location: Middle Tenessee/Northern Wisconsin/wherever else I may roam to try and make a buck.
Re: Ballast Resistor
The reason you did not see the resistor originally, is the factory one from Ford, was a resistance wire in the wiring harness, not a ballast, like you are about to install. So you can pick your own mounting place. No right/wrong.
1970 F250 Sport Custom 4x4 360 V8, otherwise known as the Hi Boy, and a Harley-Davidson.
1953 Lincoln SA200 portable welder with a 4 cylinder 1941 Continental F162 engine.
"If you think you can do a thing or think you can't do a thing, you're right." Henry Ford
it goes between the ignition switch and the coil. its #16a on this diagram: http://fordification.com/tech/wiring/68-09.jpg and looks like a fat pink wire originally.
Thanks everyone. I did some reading regarding the in-line resistance wire but wanted to confirm. Appreciate the info.
