Door Jam Switches
davbell22602
Door Jam Switches
Post by davbell22602 »
When did they start using door jam switches in the F100? Lmc is showing a door jam switch for a 67.
basketcase0302
Re: Door Jam Switches
Post by basketcase0302 »
davbell22602
I thought 67 had door jam switches. Thanks
colnago
Post by colnago »
Dang it! That's something else I have to chase down! I know I don't have the switches, or the dome light (or was that "doom" light?). This project truck keeps getting more and more involved.
Joseph
basketcase0302
davbell22602 on Wed Mar 28, 2012 7:13 pm
Dave, they're shown above in the diagram I posted, (referred to as "courtesy light switch"). :wink:
mk
Post by mk »
They were an option from 67-69 and had a separate harness that plugged into the main one.
mike
~Will Rogers
Mercury truck ID thread:
Ford truck model history:
Using dentside fender liners:
Matchbox diecast bumps:
Mach428
Post by Mach428 »
Adding these are super easy. I found the switch brackets on ebay, then beadblasted and painted them up. I used the pin switches from NPD for a Mustang (exactly the same) then made my own harness. You should already have a femaie plug on your light switch harness where the factory would plug in the couresy light harness. It took my only a few hours to make the harness and install everything. Now my courtesy light works whenever the doors are opened. Never thought something this mundane would be so exciting but it was to me!
