Random cut wires
drizzie27
Random cut wires
Post by drizzie27 »
So here are a couple issues, First i took off my instrument cluster cause it needed a make-over and i noticed random wires cut or with a butt connector and seems like a missing wires too.
First. This wire is CUT and added a butt connector that go nowhere.
This one is Also CUT, it has two wires coming down to one.
This one is also CUT but is connected to what the that button looking thing to the left
This one is Guess...CUT just comes from the braid of wires behind it.
This one isnt cut but when i disconnected everything this was tucked behind some other wires.
Just there with a boot.
Missing wires
Sooooo. Thats it haha. ANy help is much appreciated. Thanks a bunch.
1972hiboy
Re: Random cut wires
Post by 1972hiboy »
the picture showing the boot with two wires going into it and the picture showing a three holed plug with only one being used seems like these are power or grounds for plug in options like a cargo light or gas tank sending unit switch is my guess. the ones that are acually cut with wire showing should be traced with a wiring diagram since they look factory color coded to make sure they are goign where they need to be or blocked off or removed if they are added in.
Rich
Dont eat yellow snow.....
drizzie27
Post by drizzie27 »
that could explain why my gas gauge does not move at all
70-360fe
Post by 70-360fe »
drizzie27 wrote:So here are a couple issues, First i took off my instrument cluster cause it needed a make-over and i noticed random wires cut or with a butt connector and seems like a missing wires too.
[ Image ]
[ Image ]
[ Image ]
The button looking thing is a brake warning light of some kind don't remember exactly, there should a purple wire that goes to the botton also
[ Image ]
[ Image ]
[ Image ]
Missing wires
[ Image ]
Don't a have pic to look at on the quote but the black 3 hole plug comes off the main wire from the battery goes to the fuse box. The og./white white should power the windshield wiper sprayer. I don't think anything else is suppose to hook up to it.
The blue/white should go to the cig. lighter.
The brown connector I don't think it was suppose to be connected to anything. The green wires it's hard to tell if they green or green with a color strip. Let me know and I can look at a harness I have a part. The purple/yellow I'm guessing here but look at the instrutment cluster plug and see if there is a cut purple wire there. Again I can check on mine tomorrow and see.
Ok looked at the 2 green wirers again I think po used it as a hot line maybe. Don't think anything is suppose to be connected to it.
Purple/yel I think goes thur the wirer wall and out to the brake sensor. Look at the plugs the go thur the firer wall on drivers side. Also check the wirers out side the firer wall and look for a purple/yel wire
I don't think any of those wires have anything to do with gas gauge not working.
http://www.fordification.com/tech/fuel- ... -units.htm
Rattler12
Post by Rattler12 »
Picture #1 Blue/ Y stripe to horn
#2 Green/Y stripes from door switches to courtesy lights
#3 is it Red/white stripe or Red/Yellow strip? If it was to "the little button thing" it should have been attached to a lamp socket for the brake warning light and should be Red/Y
#4 Red/Y to dimmer switch
#5 Blue/W cigarette lighter
#6 Did the truck have marker lights on top? Even if not that is probably for that purpose and was just not used.
#7 The recepticle with 3 holes and only one wire hooked up I believe that Orange/W stripe wire goes to the windsheild wiper switch
colnago
Post by colnago »
Looks like Rattler ID'ed the blue/white as going to your cigarette lighter. The 90-degree end of it looks like the connector to my temperature sender/sensor on the top of my engine. However, I'd follow the wiring diagrams before I connected it to the temp probe (I don't remember the color of my temp probe wire, and it's too cold/dark to check right now). You should be able to find a wiring diagram in the tech section of the forum.
Joseph
drizzie27
Post by drizzie27 »
Much appreciated rattler, on #6 the PO had a yellow/black maybe yellow/blue wire coming out to the radio. I yanked it cause the wire was all melted and asking for trouble. So there was actually two wires originally but I pulled that one. That brake light warning one is red/yellow. Dimmer switch is that when I rotate the light switch and it dims the lights inside cause that already works? On #2 where is that wire supposed to be connected to cause my light does not turn on when I open my doors. But I also found out that the wire that connects to the boot that has the black/blue wire, it has no power but the boot has power when the truck is turn to the on position or running. And my cigarette light lee is trash the backend just falls off so I gotta figure out how to take it out. Tried taking one from a 76-78 from the junk yard but couldn't figure it out. An no no lights on top.
drizzie27
Post by drizzie27 »
Also anyone figure what #2 is with the two wires coming to the boot then down to one wire? #1 and #2 are both hot when the truck is off also
colnago
Post by colnago »
If #2 is hot when the truck is off, I betcha the PO put in a stereo, and he needed a hot lead to keep power on for his clock and station presets. I think yellow is typically used for that.
Joseph
drizzie27
Post by drizzie27 »
Maybe but the radio wasn't working when I got it that's why I just pit in the pioneer. So that makes me wonder what I should go to still or what it can go to.
colnago
Post by colnago »
Typically, radios take two power leads. One goes to the ignition, and allows the radio to be turned on. One goes to "always on" power, which allows the radio to keep its presets and clock, even when the truck is off. This wouldn't be the case for our stock radios, which have mechanical presets (remember when you pulled the button out, then pushed it in, to store your station?). But for aftermarket stuff, you'll need a constant-power source, and that's probably what the yellow is.
Joseph
drizzie27
Post by drizzie27 »
I understand what your saying. I have a constant and a hot for my aftermarket already I used a splice connecter from the fuse wire and a black wire that is always hot. I'm just curious if this is supposes to connect to something important or if I can just put a cap on it so it doesn't start a fire.
colnago
Post by colnago »
If you already have a hot, then just cap it off. From the photo, it doesn't look like it goes to anything stock.
Joseph
Rattler12
Post by Rattler12 »
Since it is hot all the time the single wire out of #2 boot could be the hot lead to the cargo light switch if it has/had a cargo light
Rattler12
Post by Rattler12 »
colnago wrote:Looks like Rattler ID'ed the blue/white as going to your cigarette lighter. The 90-degree end of it looks like the connector to my temperature sender/sensor on the top of my engine. However, I'd follow the wiring diagrams before I connected it to the temp probe (I don't remember the color of my temp probe wire, and it's too cold/dark to check right now). You should be able to find a wiring diagram in the tech section of the forum.
Joseph
H2O sender has the same 90 degree connector but the wire to it is Red/ W strip.....Blue /W is the lighter
