Headlight Question
davbell22602
Headlight Question
Post by davbell22602 »
Will I have to do any mods to fit a H6024 Sylvania headlight? I noticed there's 3 terminals on each bulb. This is for a 67 F100.
mk
Re: Headlight Question
Post by mk »
If it's a regular 7" halogen sealbeam it will fit right in. You may want to install relays for brighter lights and to take the load off the old headlight switch.
mike
~Will Rogers
Mercury truck ID thread:
Ford truck model history:
Using dentside fender liners:
Matchbox diecast bumps:
basketcase0302
Post by basketcase0302 »
2nd that-what Mike said. Most here have found out the hard way, (after having to get the truck home with lights flashing on and off). Our trucks wiring just doesn't support the extra load put on it by the halogen bulbs most of the time.
davbell22602
Who sells the relay to support the halogan bulbs? Just a universal relay works from autozone?
SmoothJ69
Post by SmoothJ69 »
if you look at the sticky for diagrams at the top of this forum section the first diagram shows how to wire the headlights w\ relays. You just need 2 generic (12v) relays.
The autozone by me does not carry generic relay's anymore (you can get them in a package that includes wiring\switch for fog lights for 3x the price) but radio shack has em in a variety of amperage sizes. I would think the standard 30amp's would be more than sufficient.
davbell22602
So is the Sylvania 6014 the sealed beam alternate version?
davbell22602
Anybody?
drizzie27
Post by drizzie27 »
that one in particular should be a direct replacement. It is incandescent but like stated above the relays will help alot. Basically that headlight is plug n play.
davbell22602
Thanks
basketcase0302
Dave,
You can also get just about any KC or off road type lighting relay to do the wiring upgrade.
Wallyworld might even have these. :wink:
davbell22602
Which do I need 3 or 4 terminal relay? Walmart doesnt have relays. Autozone just has a 4 terminal.
SmoothJ69
Post by SmoothJ69 »
4 terminals:
power in (87)
power out (30)
switch source (86)
ground (85)
drizzie27
Post by drizzie27 »
davbell22602
71PA_Highboy
Post by 71PA_Highboy »
Buy these:
http://www.delcity.net/store/Socket-wit ... _72563.a_1
Less than most places... it has the wiring socket, so it is a crimp in solution.
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
