Rear driver side brake and blinker not working
I replaced the bulb and it's still not working. When I turn my lights on the tail lights come on but I still have no brake or blinker light on that side and I also checked the wiring and it looked fine nothing noticeable. I'm sure it might be something simple...
1972 F250 Ranger XLT Camper Special 390ci Bought Brand new in 1972 and passed down from my Grandpa after he passed
RIP Paul & Von
RIP Paul & Von
- flyboy2610
Re: Rear driver side brake and blinker not working
Check your ground wires. If your wiring looks good, check to see if you have current at the wires at the socket in the back. It sounds to me like your turn signal switch is acting up. Your rear turn signal is actually just the brake light flashing on and off, so your brake light is routed through the turn signal switch. When it goes out, you lose both. Do your four way flashers work?
Red Green
you'd better be right.
Red Green
2nd vote for the turn signal. You can also go under the truck, (DS) and check for power where the harness comes out and heads to the rear.
Here was my problem... All good now!
RIP Paul & Von
RIP Paul & Von
The DS side harness that heads to the rear? What had they tied into it there? Can't say how much I dislike those cheap connectors!
