blinkers
randyvines
blinkers
Post by randyvines »
My turn signals quit the flashers still work fine but no turn indication either on dash or on the lights themselves could this be the turn signal flasher? any ideas are helpful.
71PA_Highboy
Re: blinkers
Post by 71PA_Highboy »
swap the flasher can with the turn signal can... if the problem moves, then you know what to do.. if not report back here with the results.
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
randyvines
Re: blinkers
Thanks I will swap them Have to till the garden first :lol:
randyvines
Re: blinkers
changed flasher no help :hmm:
71PA_Highboy
Re: blinkers
did you check the fusebox? do the brake lights work?
Got Ford?
1 Lincoln Mark VIII
