67 F100 wiring harness problems
davbell22602
Post by davbell22602 »
I'm trying to repair my 67 F100 2wd wiring harness. I think got everything back together except for a few wires. I have 2 cut wires that are red w/black stripe that cant figure out that are cut one near the steering column plug in and the one wire is cut on both ends and not sure where the ends up at. I have another solid red wire thats cut also. I also have a unknown colored spliced to the 70-72 steering column connector that was done by a PO. Its blue w/yellow stripe. I still have to wire up the brake light switch/brake push rod, dome light/door jam switches, and pressure brake valve switch. I was using the diagrams under the tech section but things arent matching up for I have left.
basketcase0302
Re: 67 F100 wiring harness problems
Post by basketcase0302 »
Dav,
Kind of hard to say from here where they could go. Ford had been known to change color mid-year on vehicles. If you can't trace them back to the source maybe try one of these:
http://www.ebay.com/itm/1967-67-Ford-F- ... 5648ea71f6
davbell22602
Here's some pics of what I'm talking about.
davbell22602
basketcase0302 wrote:Dav,
Those diagrams in the are basic truck diagrams. No air or radio. Doesnt know if there early or late. Thats what I got from the seller.
70-360fe
Post by 70-360fe »
http://www.fordification.com/tech/schematics_h.htm
Have you looked at these? Might want to look at 70's master diagram, I know there are some difference but similar.
I was planning on doing this later but been having wiring issues and may have to lok at it now. How much time have you got invested in the harness so far, thanks.
davbell22602
70-360fe wrote:http://www.fordification.com/tech/schematics_h.htm
I saw that diagram too but it doesnt have color chart to reference the wire colors. I have like 8 hours on this already. I just resoldered what i could match up my wire colors.
basketcase0302
Dav,
Forgot about this which also might help:
davbell22602
Thanks Basketcase0302,
I guess I need to do a complete rewire with I got and repair or fix whats needed. I guess I'll start by pulling all the electrical tape.
70-360fe
Post by 70-360fe »
http://www.fordification.com/tech/wirin ... ghts01.jpg
Some diagrams have the color code some do not here is one that does. You just have to jump around and write them down.
http://www.fordification.com/tech/wirin ... gauges.jpg
Heres another one
If you look at the first diagran 284 is the code for a red wire it goes to the stop switch by the brake petal. I know its from a 70's truck but I found there are few differences. I do know the voltage regulator on the 70's and 67 truck has a slight difference.
If you look at first diagram again red/blk. strip is code 13 it connects to the yellow 4 prong connector. At the the connector 13a (same color) contines on from there.
Just remembered I have a 67 wiring harness I picked up at the junkyard to fix my harness. It's late so I will look at it tomorrow and see if can help.
davbell22602
Thanks. I gonna rip off all the electrical tape and do a rewire on whats missing for now.
davbell22602
Still having a few issues with the wiring harness.
Where does the red black wire go to thats on the plug for the brake switch? Where does the green wire go thats on the brake pressure diff. valve thats on the inner fender? Where does the black wire thats coming off the instrument cluster plug in goes?
Also what is this for? It has 2 wires on it. one black w/red and black w/orange on it.
davbell22602
anybody
SmoothJ69
Post by SmoothJ69 »
the green wire off the brake pressure switch goes through the ignition switch to the brake light on the dash
the red\black wire from the brake switch (on the pedal) goes to the turnsignal switch.
davbell22602
SmoothJ69 wrote:the green wire off the brake pressure switch goes through the ignition switch to the brake light on the dash
Which wires are they joined/soldered together with since there isnt enough terminals for each individual wire?
SmoothJ69
Post by SmoothJ69 »
The green wire goes from the brake pressure warning switch to the ignition switch (and back out like a Y), to the light on the dash. it remains the same green color the whole way. You have to remember the brake pressure switch (and light circuits in general) is just a loop : ground > switch > wire > ignition (aka 12v power) > light bulb > ground ...if the switch looses pressure, it grounds out, completes the ciruit and lights the light.
The red\black wire goes from the brake switch (on the pedal) to the turn signal harness, there it splits (like a Y ) ..the end that comes out of the same side then goes on to the emergency flasher switch. It also remains the same color throughout.
like this:
Brake switch Emer-Flasher switch
plug
Turn Signal
