1.5ohm or 3.0ohm 40,000v coil?
HDxLoki
Post by HDxLoki »
I have electric ignition swapped out for original points ignition. I have the original coil on there now and was wondering what I would get the best performance out of. Im buying a FlameThower Coil but If there's anything better let me know or if there's any better brand that make good coils! Thanks!
(1972 Ford Ranger with 390ci)
1972 F250 Ranger XLT Camper Special 390ci Bought Brand new in 1972 and passed down from my Grandpa after he passed
RIP Paul & Von
Montana71-F100
Re: 1.5ohm or 3.0ohm 40,000v coil?
Post by Montana71-F100 »
I bought my electronic ignition conversion kit from http://www.hot-spark.com/1-3FOR8U1.htm Since it's the only one I've tried, I can't say it's better or worse than anything else but I haven't had any trouble with it. My original coil had a different resistance than they recommend so I bought the one they sell that matches their kit. http://www.hot-spark.com/1-HS17HEC.htm
basketcase0302
Post by basketcase0302 »
Should be able to get an answer here:
http://www.pertronix.com/support/contact/default.aspx
Mancar1
Post by Mancar1 »
I have had good luck with my flame thrower coil. 68 CS 390 :thup:
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
